journal-article
- E.P. Montellà, J. Chauchat, B. Chareyre, et. al. A two-fluid model for immersed granular avalanches with dilatancy effects Journal of Fluid Mechanics 2021 10.1017/jfm.2021.666
- William Chèvremont, Hugues Bodiguel, Bruno Chareyre Lubricated contact model for numerical simulations of suspensions Powder Technology 2020 10.1016/j.powtec.2020.06.001
- Caulk, R., Sholtès, L., Krzaczek, M., et. al. A pore-scale thermo–hydro-mechanical model for particulate systems Computer Methods in Applied Mechanics and Engineering 2020 10.1016/j.cma.2020.113292
- Caulk, R.A., Catalano, E., Chareyre, B. Accelerating Yade's poromechanical coupling with matrix factorization reuse, parallel task management, and GPU computing Computer Physics Communications 2020 10.1016/j.cpc.2019.106991
- Montellà, E.P., Chareyre, B., Salager, S., et. al. Benchmark cases for a multi-component Lattice–Boltzmann method in hydrostatic conditions MethodsX 2020 10.1016/j.mex.2020.101090
- Montellá, E.P., Yuan, C., Chareyre, B., et. al. Hybrid multi-scale model for partially saturated media based on a pore network approach and lattice Boltzmann method Advances in Water Resources 2020 10.1016/j.advwatres.2020.103709
conference-paper
- Montellà, E.P., Yuan, C., Chareyre, B., et. al. A hybrid multiphase model based on Lattice Boltzmann method direct simulations 8th International Conference on Computational Methods for Coupled Problems in Science and Engineering, COUPLED PROBLEMS 2019 2021 2-s2.0-85102150198
- Pekmezi, G., Littlefield, D., Chareyre, B. Statistical distributions of the elastic moduli of particle aggregates at the mesoscale 2019 15th Hypervelocity Impact Symposium, HVIS 2019 2021 10.1115/HVIS2019-052
- Puig Montellà, E., Yuan, C., Chareyre, B., et. al. Modeling multiphase flow with a hybrid model based on the Pore-network and the lattice Boltzmann method E3S Web of Conferences 2020 10.1051/e3sconf/202019502009
book
